No of visitors who read this post: 216
Category: iPhone
Type: Question
No votes yet
I want some technical details about apple iPhone 3GS.
I want to know about its functions like multi-tasking, USB transfer and flash lite.
And I also want to know about its Operating System and its In-built memory.
Comment viewing options
iPhone 3GS consists of a 3.5 multi-touch display that is able to identify two or more points of contact on the apparent all together. The USB 1.1 supply maximum speed with up to 1.5MB/S wherein the latest USB 2.0 is 40 times faster. The USB is common for wired connection between two electronic devices such as mobile phones and a computer.
The iPhone 3GS doesn't have a memory card slot. You can choose from the internal memory of 8GB, 16GB and 32 GB with 256MB RAM. A process of arranging various types of data on phone memory is called shared memory while the Dynamic memory is the type of data that are gathered under the same memory. One advantage of the dynamic memory between a partitioned memory is that, it is more adjustable. You can add your pictures on the memory and yet you don't need to take another photo even if there is nothing stored on the other memory.
# (Solution Accepted)
Hello, my name is muhammad agung purwanto. now i want to answer for this question.
Apple iphone 3GS have a height 4.5 inches, width 2.4 inches, depth 0.48 inches, and weight 4.8 ounces. beside of, in apple iphonne 3GS available 8GB flash drive capacity, wireless signal for UMTS/HSDPA (850,1900,2100 MHz).
then, function of the multi tasking is we can open 2 or more the application at the same time. beside of, apple 3GS available USB transfer with USB cable, with USB cable we can transfer data like a music, file, and etc. then we can charge from the laptop or pc with USB cable (USB tranfer).
Flash Lite is demulcent version of ordinary Flash Player Adobe we enjoys while browsing Internet at computer. Made by special for works at mobile's peripheral as hp. Flash Lite can play flash's application or game that is at one sites.
apple iphone 3gs utilizes IOS.3'S operating system as initial of its operating system, meanwhile operating system most in height utilizes iOS.4.3.3 and iOS.5.0 (beta version).
graph that is utilized on apple iphone 3gs same with graph which utilized  on apple iphone 4. besides equalities on graph, codec's audio that is utilized on apple iphone 3gs with also as apple iphone 4 which is utilizes Cirrus Logic CS42L61.
memory's capacity on apple iphone 3gs which is: 8GB, 16GB, and 32GB .
that is detail's explanation about the Apple Iphone 3GS
thank you
