Need help to resolve problem with Windows Media Player
Dear Experts,
I am using Windows XP on my laptop. For music files I use Windows Media Player 12. I am having a continuous problem that few files wmp pcm audio are not being played. Can you resolve this issue?
Answered By 0 points N/A #159077
Hi Bersh Roman,
This problem occurs due to codec related issues. Please follow the below steps to rectify the issue.
  • Install FFDShow codec.
  • After installing the above codec, do the following.
  • Go to Start > All Programs > FFDShow > Audio decoder configuration. Enable LPCM and set MS ADPCM, IMA ADPCM and all Other ADPCM to 'libavcodec'.
  • Now, install the latest version of Haali's Media splitter(Matroska Splitter) and make sure that both 'Enable MPEG-TS support' and 'Enable MPEG-PS support' are checked.
This will solve your issue.
Its preferable to switch to some audio players like Winamp or VLC media Player.
Hope it helps.
