Need help to Create Report from Excel Data.
Hello Guys,
I have created an Excel File that has some records in it. I have to create a Visual Report from the data present in MS Excel. Can someone tell me how I can Create Report from Excel Data?
Answered By 0 points N/A #177586
You have to follow the steps to create a Visual Report from an Excel Data.
1) In the View Tab, click on “Visual Reports.”
2) The Visual Reports Dialog Box will appear.
3) Click on the Report that you want to make.
4) If the Report is not listed, click on “Import Report Templates.”
5) After that, select “Modify”, and browse for your File.
6) Change the level, if you want.
7) Click on “View” to see your Report.
