Need a bat file flow editor
I have been using a lot of bat files in my projects but right now some audit is going on to check the flow I need a bat file flow editor to maintain the flow is it any tool available for to measure the flow where they are used
Answered By 0 points N/A #168945
Hello there John,
There are no good editors to maintain and control the flow of Batch Files but there are quite a few scripting techniques you can use to accomplish your task.
You can access all the scripting techniques relating to Batch files here.
Most of these scripting techniques work for both "DOS Batch files" and "Windows NT Batch files".
However, for every technique the supported OS versions are mentioned as a bubble next to the name of the technique.
I hope this should help you accomplish your task.
Cheers.
