Need the asrock sound drivers for Windows XP
Hello expert, Recently I formatted my PC. But I Iost the sound drivers of my PC. So I need the asrock sound drivers immediately. My PC’s operating system is windows Xp. Please send the download link or CD try to send the latest version of asrock sound drivers for windows xp.
Answered By 60 points N/A #165493
Hello Thor Peiann,
Asrock audio drivers are available as per the available motherboard models.
Here are the some links to download Asrock audio drivers:-
In H67M motherboard series (here you can find the links as per region)
In G41M-VS3 motherboard series
And here is the link to download latest driver update
Hope this will help you to download the appropriate drivers.
Thanks,
Alisha B Stone
Answered By 590495 points N/A #315066
If you lost the driver for your sound card, it shouldn’t be a problem because the driver can always be downloaded from the manufacturer’s website. Go to ASRock Support page to get the latest driver. Here, enter your computer’s model number or your motherboard’s model number to search for the product. You can find the model number on the side or bottom of your machine.
When the product is found, click it to go to the download page. Select your correct operating system then download and install all available drivers and software for your system. This should fix the problem.
