No of visitors who read this post: 223
Type: Question
Author: Alex whisler
No votes yet
My hard drive has stopped working. I have some really important data in it which I cannot afford to lose. To be honest it has my son’s pictures and videos, from when he was really young. I really should have backed up my data. But for now I need your help to get that important stuff back.
The problem started when my VAIO PCV-RS420 gave a ‘slave drive error’. This problem happened a couple of days back when one of my two WD hard drives stopped responding. So I took the drive off, from the ASUS Mobo and booted the system. The system worked fine, without the drive. But when I tried to connect the drive externally the computer did not show the drive. Altho0ugh it did recognize the drive as an usb mass storage device. At that point it was clear to me that although the drive was not completely dead, there was something definitely wrong with it. Oh, and one more thing, when I first had problem in booting the system, it had shown a ‘bios setup utility’ which I cancelled. But at this point, when connecting the hard drive with an IDE adapter did not work, I reverted back to the original bios setup utility. Right now, it had been more than 5 hours, and I am still waiting for the Bios scan to finish. Like I said earlier, this data is very precious to me. It is not like I care for the drive or the hardware. I want to preserve those pictures and videos. So I urge you to post any helpful suggestion that you can think of. Have a great day, Bye.
Comment viewing options
Hello Alex Whisler,
Your system's slave hard drive has failed because of some storage related issues. Your son's pictures and videos can be reloaded as they are still there in the slave drive. For restoring your son's pictures and videos, use a reliable Hard drive data recovery software utilities or any disk recovery tools. Here are some useful links:
http://www.stellarinfo.com/digital-media-recovery.htm
http://www.stellarinfo.com/windows-data-recovery.php
http://www.easeus.com/datarecoverywizard/free-data-recovery-software.htm
When running your data recovery software, make sure you use them as the Administrator. Do not panic, try checking the task manager to see the ongoing processes, this may help you locate some files operating from the slave drive. If not, then open Run window; type “recent” and press enter to see the files and folders that you have opened. From these, look for a file that was in that slave file and right click on it and go to properties, collect the location and navigate to it and/or try to run the recovery file by putting in that location. Then your data will be recovered. Follow the recovery methods of your recovery software and your data will be restored. Next time, remember to always keep backups. If the problem is still not solved, contact an IT expert near your area.
Hope your problem gets solved soon. Best of Luck!
