My Samsung Galaxy ace cant play wma, why?
Hello techyv.com!
I have here a Samsung galaxy ace, and I have been using this for watching videos since I bought it. I'm not really into downloading lots of applications, I've only downloaded those interest me.
Now I have here a video file that I wanted to watch but is in wma format and I can't play it with this format.
Please help find a way because my Samsung galaxy ace can't play wma.
Thanks!
Answered By 40 points N/A #170674
Hello, Samsung galaxy ace,
Which runs on Gingerbread OS, Most of the Android phone can't play wma files till gingerbread OS. To play wma files, either you can convert the file or find the compatible media player on android market.
You can play wma files on Poweramp player which is a good player or look for another host of media player. Now if you want to have the converter then there is Format Factory, which will convert all your wma files and play with your default media player.
Try to be active on the market place.
You will come across with so many good apps Thank.
