My RAM Usage Don”t Add Up As Shown In The Task ManagerHe
I have been encountering this problem for a while and would like to have some insight as to why.
My RAM usage reaches 80% even though I have no huge processes running. I tried to add all the processes but it wouldn't even reach half of what is shown
I would appreciate if someone would answer my question.
Answered By 0 points N/A #177874
Hello Edward
Basically the usage of RAM is not related to processes since the RAM is a memory ( Random Access Memory ) for which it stores data for the software and the OS in order to perform the process.
The usage of RAM can be 80% or even more if you have low RAM and :
  1. Using a theme for windows that has lots of graphics
  2. Using many apps at the same time
  3. Using web browsing and having more than 10 websites open on a browser like chrome or firefox
  4. Multiple tasks
All of the previous tasks causes an increase in RAM usage, i recommend that you increase you RAM since the recent apps uses lots of graphics and requires lots of memory of the computer.
Regards
Browen
