My net is disconnecting rapidly
I have a broadband(With Wire) connection. My network is disturbing a lot. My net is disconnecting rapidly. Can anyone help?
Best Answer by Dave Kaun
Answered By 0 points N/A #112001
  • There can be many problems. It could also be a defective modem. So check your modem first, and if its faulty then ultimately the problem will be resolved after replacing the modem.
  • Since your are on wire connection then it could be because you are not getting enough bandwidth or signal strength from your router or ISP. Better contact your internet service provider. They will usually know how to fix any internet related problem specially if you have frequent disconnection.
  • The other case can be, that you have run out of your allocated bandwidth. Usually Internet service providers will generally limit the amount of data being sent/received from your computer in the case of excessive bandwidth usage (specially when you are downloading). This may tend to slow your connection, some times ends up in disconnection.
Answered By 0 points N/A #112002
You are using wire+ broadband line. This often create this kind of problem. You might have TPLINK wire Broadband Router. Router helps you to Destribute your Internet. This is not a problem of Router. So do not think that you have a problem in your Router. Your Router is fine. You have problem in your Connection. So you may talk with your distributer who gives you the connection. But if there is a problem in your Router then cosult with an expert. You might Repair your Router from a servicing centre. Sometimes Due to bad whether the connection disturb much. I think this will help you. I hope this will give you some relief.
