My game cold fear crash on win 7.
My game cold fear crash on win 7. I want to know the requirements needed to install and run the cold fear crash game, if it is not compatible with windows 7 operating system then what will be the required one? I know you can help me about this.
Waiting for your support, thank you.
Answered By 0 points N/A #188122
Cold Fear game is compatible with only "Windows 2000" and "Windows XP" according to the Ubisoft official website. And the other system requirements are,
* 2.2GB of free Hard Disk space
* 256MB RAM
* 64MB video RAM supporting DirectX v9
But there is nothing to worry about your OS since you have WIN7, because there is a option called "Program Compatibility troubleshooter" which enables you to run programs designed for previous versions of Windows OS. You can follow the below instructions.
* Click on "Start", and then go to "Control Panel".
* Then on search box type "troubleshooter", then select "Troubleshooting" from the search results.
* Then click on "Run programs made for previous versions of Windows" listed under "Programs".
* Then follow the onscreen instructions in the troubleshooter.
