My device won’t connect to the WiFi
Asked By 100 points N/A Posted on -
What prevents my devices from connecting to the home WiFi? I have recently noticed that my devices are no longer connecting to the home WiFi. I have troubleshot the router many times by changing the setting and even upgrading the router firmware, but the devices won’t connect. What can I do to make the devices connect to the Home WiFi?
Best Answer by Ion Hathew
Answered By 0 points N/A #189384
Here are some of the things that a device won't connect to a WiFi: First, WiFi is not ON yet on the device and the source. Second, the signal is out of range or poor signal is being encountered by the device. Third, WiFi name is not registered correctly with the device. Fourth, WiFi password may have been updated and forgot to do the same with the device.
Answered By 0 points N/A #189385
Just Forget the your wifi signal from the device and change the wifi password of your router and try to connect it from there.
If the problem continue, here is the other problem.
Just try to connect your device by pressing the pin button with your wifi router power on of device and press it one time and connect the wifi at the same time to your device and it will connect.
