In my computer, games are running very slow. please help !
Hi all,
In my device manager , under sound ,video and game controller- it shows unsupported standard game port. I don't know why games are running very slow. Before opening of the games it shows the message "hardware acceleration is either disabled" I uploaded screen shot of the message if any one know please help me to solve the problem.
The game is running in software rendering mode
Hardware acceleration is either disabled
or not supported by your video card
driver, which could slow game
performance. Make sure you have the
latest video card driver installed and that
hardware acceleration is turned on.
                                                           OK
Best Answer by tmgtuhin
Answered By 0 points N/A #128673
Dear Anjalo,
It is not a big problem. It seems to be you don't have installed your graphics driver. You don’t give any details about your computer manufacturer or your motherboard provider.
You should go to your graphics hardware manufacturer website and should download the latest driver for your graphics hardware. Or give us full details about your computer and we might can help you to fix that.
Thank You.
Answered By 5 points N/A #128674
Hi dear,
You can solve this problem easily. All you need to do is increase our RAM capacity. You did not describe about your system configuration but you should have do that because only then we can measure your real problem and solution will be perfect. It’s all right then.
Processor speed does not matter. 2.66 gh will be enough for gaming if you have graphics card as coprocessor. You need to add a graphics card. It will be AGP, PCI express or 3D and careful about installing its driver software. Your hardware is not creating problem. it is driver software. So update your system will do the job.
