Mouse push effect software for ms access
I'm working in ms access, want to add mouse push effect for the button's. Is there any softwares that give mouse push effect for the ms access push button or is it can be done with coding? give me some idea to add mouse push effect.
Best Answer by Dyer Pearlman
Answered By 60 points N/A #163631
Hi Denise Collins,
I have seen a possible solution with your concern. Peter's software is a Mouse Over effects (MOE). It is very easy to download with a low Byte consumption. I have attached the link of this software for your reference.
Peter Software Mouse Over Effects (MOE)
Hope it would help you a lot.
Answered By 0 points N/A #163632
Hello Denise Collins,
There is a software know as Mouse Over Effects (Moe) developed by Peter’s Software Company. This is an add-in for Microsoft® Access® that can add rollover-type effects on your forms that can react to mouse actions. Please see this for downloading the software.  http://www.peterssoftware.com/moe.htm
You can download this software and install it. It has a user friendly interface and you will achieve your goal easily.
