Most accurate GPS map application for Samsung Galaxy Note
I already tried SYGIC but still not contented with its accuracy. Some places are not detailed yet. Is there an application better than SYGIC. I have read about an application called NAVDROYD but still not tested it yet.
Best Answer by Valbuena jane
Answered By 5 points N/A #119891
Here are some of the applications which I would recommend:
NDrive is the best according to me. Great accuracy and reliable
This is how you download the same:
1) Find NDrive Software
2) Download and then extract the .map file to NDrivemaps
3)If NDrive doesn't find the map then you need to remove the _TA or _NT from file name.
You can also try  Sygic, Co Pilot 8, iGo, Viewranger . Runkeeper is another application that helps in  tracking your routes when running / walking.
Answered By 5 points N/A #119892
Hi
GPs are nice apps for some hand held Smartphones like the Samsung galaxy but there are a lot of apps on line and some of them
Are not that accurate I use backpacker GPs trails in Google play store here the ink  https://play.google.com/store just check for other GPs apps available.
