anonymous
7060 points
Posted on - 02/26/2013
Hello, my pc is running fine suddenly, it shuts down by itself.. when i tried to turn it ON, my PC is running but my MONITOR shows NO SIGNAL INPUT.. i already clean my ram, tried another slot and return it to original slot but still not working.. also changed by cable monitor.. still not working.. what do i need to do?
MONITOR SHOWS NO SIGNAL INPUT
This means there is no video coming from the PC
The problem could be a poor connection, the video card being faulty. Try to unplug the PC and open it and clean out the dust. Check all the cables and also memory cards video cards, and sound cards.
Check there also is no bent pin at the connection. You could also get a working monitor and see if it works before concluding if yours is the one at fault.
Hey,
As you have stated above that your pc was running fine it suddenly shuts down by itself and as it also shows NO SIGNAL INPUT. First of all check the input cable from CPU if the problem still persists then you will definitely solve your problem by reading why monitor is showing no input signal?
Hope this will help you a lot
Thanks and Regards
Gillam Janetj
