Missing or corrupted and Topicscape Pro need them to operate
While I load the certification, Topicscape did not explore.
I can view Topicscape.exe for a short time with the Task Manager however it hide from there after some seconds and no Topicscape windows or buttons yet show on the desktop.
Eliminating the file and attempting to begin Topicscape produces an error message that files are missing or corrupt.
Somebody can assist me in the matter?
Some files are missing or corrupted and Topicscape Pro need them to operate.
Some files are missing or corrupted, and Topicscape Pro needs them to operate.
Answered By 50 points N/A #176215
Hey Carlos,
What you need to do is remove it and reinstall it, You need to find where the file is located, I'd suggest just typing in the file name in the search bar on your computer and it should locate it. If that does work try ending the program on task manager. After your done with that just try re-installing it and it should work perfectly fine.
Thanks for reading.
-James C Montes
