Mindjet MindManager System Error occurred
I have begun exercising MindManager and I like it extremely. I have to perform an appearance next day and my brand fresh PC dislike MindManager. I received an error message which you can see below in the attached image occurs at the time of my attempt to explore the program. Can somebody resolve this matter please help me?
XML processing error Core initialization 0x800040154
Core initialization
0x800040154
Answered By 0 points N/A #176519
The cause of this error message is that the file is either damaged or missed due to a virus or has been deleted from the system accidently. To fix this error, you will have to replace the missing file from another operating system. Re-start  the system and reboot the computer. The file name is Mindjet.MindManager.Interop.dll. May be you also have to register the file. I hope the problem will be resolved.
Answered By 590495 points N/A #327544
If you want to install MindManager but you encounter this error, check the system requirements of the version you installed and verify that your computer meets those requirements. If this is not a problem, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install. Once installed, start Revo then select MindManager among the applications and click “Uninstall”.
Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then install MindManager back. If this doesn’t work, download the latest free trial. Download MindManager 2020 for Windows. It supports Windows 7 Service Pack 1 and Windows 10.
It requires 1 GHz Intel Pentium or faster processor, 2 GB RAM, 830 MB free space, and 1280 x 720 minimum screen resolution. For prerequisite, you need Microsoft .NET Framework 4.6 or higher.
