MindGenius cannot start because your license has been moved or deleted.
I am exercising MindGenius and it was certifiable. However at the present day while I am attempting to begin MindGenius. I received a licensing error message. What is this and how I can remove this error please help me?
If you have recently run registry cleaning software this may be the cause. Reinstall MindGenius to restore normal operation.
For more information visit the MindGenius knowledgebase at www.mindgenius.com
OK
Best Answer by Carl M Poston
Answered By 5 points N/A #176270
This is a known issue with MindGenius. Simply click on the Start button and then type appwiz.cpl and locate the MindGenius to remove it. Open your Registry Editor and expand the folder HKEY_CLASSES_ROOT>vdsp and delete it. You can also call the MindGenius support to report this issue.
https://www.mindgenius.com/Support.aspx
Answered By 50 points N/A #176271
Hi Vivian R Simpson,
I have faced the same problem myself.  I have a solution for you.
  • Switch on your system, Click the Start button, then click Run.
  • Type appwiz.cpl and press Enter.
  • Locate MindGenius and click Remove.
  • Click the Start button, then click Run).
  • Type regedit and press Enter.
  • Expand the folder structure to HKEY_CLASSES_ROOT > vdsp
  • Delete vdsp.
  • Close the registry editor.
Still, if you get an activation error message call MindGenius to retrieve an activation code on this number 01355 24 7766.
I hope it will do the needful.
