No of visitors who read this post: 1785
Category: Mcafee
Type: Question
Author: Howel dinh
No votes yet
Hello experts
I have an excel based application created using Excel4 macros and VBA. It keeps on getting "Microsoft Visual Basic System Error &H80004005 (-2147467259)" error at startup when using McAfee antivirus. The same application works fine with other antivirus software. Is there any security option in McAfee to block VBA and excel4 macros? I dont have any idea about McAfee security settings since I'm new to it. Make sure to tell me if I have any option to block macros via McAfee controlls.
Comment viewing options
Hi there,
This problem normally happens when there is an error in any of the windows classes implemented by the comctl32.dll. This problem normally occurs when after building a .exe file from VB 6.0 and is attempted to be run outside the VB IDE.
To fix the problem, you have to call up the following command in your ActiveX control
“InitCommonControls(void)” or “InitCommonControlsEx(LPINITCOMMONCONTROLSEX lpInitCtrls)”
This command ensures that the comctl32.dll is loaded and initialized whether it’s executed in a VB IDE or natively on windows.
There is another way of calling InitCommonControls from the control’s code. The command is shown below.
“Private Declare Sub InitCommonControls Lib "comctl32.dll" ()”
And add a call to
“InitCommonControls”
Hope that helps.
