Microsoft Silverlight is currently not supported
Once I record test steps by utilizing coded a test builder I am receiving the following error. See below and help me to solve this matter. Thanks.
Error
Microsoft Silverlight is currently not supported. Go to https://docs.microsoft.com/en-us/previous-versions/visualstudio/visual-studio-2010/dd380742(v=vs.100) for information on available add-in for possible support.
Answered By 0 points N/A #175124
Hi Scot,
This error can be solved in following two ways:
1)    Turn  off the Action Log Data Collector. This message  will then go off.
·          In Testing Center click on Plan (it shows the current test plan).
·          Click on Properties.
·          In "Run Settings" / "Manual runs" section choose 'Local Test Run' for "Test Settings".
·          Then click Open link next to this drop down.
·          In the opened window select Data and Diagnostics and uncheck all items under Role Local.
2)    UI automation for Silverlight apps now available in feature pack 2 for VS 2010. Install pack2.
The feature pack contains some much awaited bits with which you can:
·          Use Microsoft Test Manager to capture and playback action recordings for Silverlight 4 applications.
·          Create coded UI tests for Silverlight 4 applications with Visual Studio 2010 Premium or Visual Studio 2010 Ultimate.
·          Edit coded UI tests using a graphical editor with Visual Studio 2010 Premium or Visual Studio 2010 Ultimate.
·          Use action recordings to fast forward through manual tests that need to support Mozilla Firefox 3.5 and 3.6.
·          Run coded UI tests for web applications using Mozilla Firefox 3.5 and 3.6 with Microsoft Visual Studio 2010 Premium or Visual Studio 2010 Ultimate.
