Microsoft Infopath 2010 Installation Error
When I tried to upgrade my Office 2003 to Office 2010 Professional Edition in one of our XP machine I got the following error message:
"Microsoft Office Professional 2010(TEchnical Preview) encountered an error during setup. Error 1327. Invalid Drive F:"
Even though with this error Office 2010 got installed. I thought that the error occurred due to lower versions of office installed on my PC.
I even tried by upgrading only Infopath 2010 but got the similar error.
Setup failed. Rolling back changes………………….
Best Answer by Stark P Blake
Answered By 0 points N/A #198490
Hello James,
This is a known issue and it is caused due to an incorrect value in the data field of a registry key. To fix this you will need to get access to the Registry Editor, find the registry key and edit it so that its value is right. Here are the steps to follow from Microsoft's support centre: https://support.microsoft.com/en-us/help/327763/you-receive-an-error-1327–invalid-drive-error-message-when-you-try-to?fr=1
P Vhilary
Answered By 0 points N/A #132949
Hello James,
This is a registry key related problem. To solve this problem follows the following steps:
  1. To open Registry Editor, click Start > Run
  2. In the Open Box, type regedit > OK
  3. In the Registry Editor go to the following key:
          HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerShell Folders
  1. Check the values in the Data field on the right pane. If it contains a drive which is incorrect for your computer, then right click the entry and type c:my documents (assume that your OS installed in C drive) in the Value data box. Click OK.
  2. Step 4 should Repeat for every entry where Data value contains incorrect drive.
  3. Repeat step 3 to step 5 for the following registry keys:
          HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorer User Shell Folders
          HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersion
          HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionExplorerShell Folders
          HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionExplorerUser Shell Folders
  1. Close Registry Editor after completing the steps.
