No of visitors who read this post: 250
Category: MS Groove
Type: Question
No votes yet
Hi.
How can i avoid Microsoft Groove from popping up every time i switch on and start my computer? I unchecked Groove related entries from start up tab in MSCONFIG but it did not solve the case.
Comment viewing options
Click the Start Button on your computer, go to Run or you may also press the windows Key and the letter R simultaneously . YOu will see a pop up box saying "type the name of the command or program and windows will start it for you", type in MSCONFIG and then press enter. You will then see a pop up box, on that box, select the START TAB, and then look for MS Groove from the list of the program. Uncheck it and then reboot your computer.
