Good day to you!
Please guide me, I'm a little bit blur of this matter.
I owned a Mac which uses Microsoft excel 2008 with an extension of xlsx.
What is the extension for the latest Microsoft Excel on windows for Mac version 12.1.0?
Thank you....
Hi Florjane,
I have some information and ideas and I am looking forward to answer and help you. As I read your question regarding of the latest extension for MS Excel on windows for Mac version here some guide of extension; .xlsx is the extension for excel workbook, for templates the extension are .xls and .xltx. And if you are pertaining to workbook the latest is .xlsx and for Excel Macro-enabled workbook is .xlsm and for template is .xltx and for Excel Macro-Enabled template is .xltm and for excel Add-In is .xlam. Additional information, If you are trying to send .xlsx some of your recipient will have problem in opening file and i suggest to change the extension file. The new MS Excel you can also save file in other extension file and i think their will be a choices in choosing the file as "save as" and try to open it and then try to send to them if they can open it.
I hope it will help you and gain information to answer your problem.
