ria tolart
10 points
Posted on - 04/03/2013
I have recently upgraded my OS to Windows 7 64 bit from Windows XP 64 bit. Ever since the upgrade, I cannot update my Windows Media Player security updater. How can I get the update? I have Windows Media Player 11.Â
Media player security updater not updating
You can fix this issue using the security update for Windows Vista and Windows 7 x64. You have to follow some easy steps to download it properly.
1.   Click on Download and change the language whichever you want.
2.   Run the program for the installation.
3.   Save the download copy on your computer.
4.   Restart the PC for best effect.
Download from the following link. I hope you will resolve this issue easily.
http://www.microsoft.com/en-us/download/details.aspx?id=13262
