MCafee Total Protection Installation Cannot Start
I am having trouble on reinstalling McAfee Total Protection. I've tried to uninstall it because it is crashing and giving me some error but now it could not be installed anymore. I also have java in my computer.
Any way to reinstall my McAfee?
We're having trouble installing your McAfee software. Please make sure you have JavaScript installed on your PC, and that it's working properly before continuing.
Learn more by visiting the McAfee support website at
https://service.mcafee.com/?cid=62492
Best Answer by Thathri elsebet.
Answered By 0 points N/A #146324
You did not mention the configuration of your systems. However, there is a problem with the McAfee software you have collected. Before installing any software you should think about the compatibility issue whether the software you want to install is compatible with your current configuration. You should also take extra care while selecting a copy of software. It should not be corrupted or inappropriate.
You should purchase it from the appropriate authority of McAfee Antivirus software. Antivirus is the most important program on your system. It protects your whole system. Otherwise your whole systems may crash in a moment. So take care about Antivirus.
I hope you understand it.
Answered By points N/A #146325
McAfee is a good antivirus software. It's been a bad luck for you not to be able to install the program. In order to fix the JavaScript issue, do the following:
1. Start Command Prompt with administration privilege.
2. Run the following command:
regsvr32 jscript.dll
Now try to install your McAfee software. You're good to go!
