MAXScript File In Exception Error
Hello TechyV people!
I'm new to MaxScript, hope you can help. I'm learning some tutorial scripts from a friend/instructor and I met this error under Export File command. Nothing I try seems to work.
Can anyone help me resolve this error?
Thanks very much for your suggestions.
MAXScript FileIn Exception
 –Runtime error: fileIn: can’t open file – “”
Answered By 0 points N/A #96715
You just simply download the error repair tools and the after you download the error repair tool to your machine you just simply install that to your machine and then after installing the software you just simply restart your machine and then after restarting you PC try to start scanning your system and then after scanning your machine just simply repair the found errors to your machine and then try to scan the software if there an corrupted files and then just simply scan the system if there an infected files to your machine just simply try that one to your PC.
