No of visitors who read this post: 219
Type: Question
Author: Lark7t7
No votes yet
I already done some procedures to troubleshoot the PC running in Windows 7 Ultimate then the Router Lynksys E1000 then it just still not working, still can't connect to internet and i try to check the configuration of the router then it does perfectly, and I ping the router it is good it does reply.
And Windows stated problem said " cannot connect and detect the Primary DNS on the device".
Comment viewing options
# (Solution Accepted)
Try to log into the router and then disable the security. Check if you can now connect. If you connect your router security must be the problem why you can’t connect. There might be an instance that your wireless driver is the problem. You need to update it. To update it, go to device manager then right click the wireless adapter then click update driver software.
If still no luck, try to reset the router into factory settings then re-configure it again. Check also your computer, maybe the error is not on the router and it’s on your computer.
Hope it helps. Good luck.
