Looking for a method to post through Microsoft Outlook.
Asked By 15 points N/A Posted on -
I've a busy person and I do emails most of the time. I've been fiddling close to look for a method to upload account configuration from windows mail and post the actual through Microsoft Outlook 2010 however without any good fortune.
Any person with an idea on this matter? I badly need your help on this matter. Thank you so much! 🙂
Answered By 0 points N/A #107062
Try this:
Go to
>file
>open
>import
>in the import wizard dialog box choose:
>import internet mail and addresses
>click “next”
>select outlook express 4.x, 5.x, 6.x or windows mail
>at the bottom, select what you want to import.
>click next.
>select how you want the import wizard to treat duplicate items.
>click finish
>the import process will start and you get an import summary dialog which you can close by pressing ok.
Here is another way of doing it if you find the first one complicated:
>load outlook
>click file
>import mail settings and it will allow you to transfer over settings, old emails and addresses.
