LOLRecorder.exe has .Net Framework Initialization Error
I finished to install League of Legends and when I tried to play the game this error message box appeared and killed the mood. I didn’t find any answer on the official LOL website and I thought I should try in here. Is there anyone that can help me to fix this ? What should I do so I can play the game ?
Thank you !
LOLRecorder.exe – .Net Framework Initialization Error
Please set registry key
HKlMSoftwareMicrosoft.NET FrameworkInstallRoot to point to the .NET Framework install location.
Answered By 70 points N/A #177450
It sounds like “LOLRecorder.exe” is unable to find out the installation of .NET Framework of your PC. You might need to repair the installation of your .NET Framework installation or get the latest version of .NET Framework.
First of all, check that if your PC has got .NET Framework installed. Go to Start menu >> Control Panel >> Programs >> Programs and Features. If you see .NET Framework on the list, right-click on it and select “Repair”.
If you don’t see, it means that you don’t have any .NET Framework runtime installed which is very important for your PC. Download .NET Framework 4.5.1. Since now, it is the latest version and able to support programs that require older version of .NET.
