Logitech m325 driver causing the issue
I have Logitech Mouse. It is wireless comes with Bluetooth technology., But I am unable to find the issue with that. When I connect it to my system, it does not respond. I tried to find the issue. What I find that it is a driver that’s not working. But I was unable to find the driver of that. I tried everything but unable to find the issue.
Answered By 0 points N/A #185717
Yes, you are right, it is the driver issue. You need to install the Logitech m325 driver to your system. With some mouse a CD comes which contain the driver. Try to find the CD and install the driver for it. If you do not have the CD then go to the following link and download the driver for it and install the driver to your computer from it and then restart your system and then it will work well.
To download the driver, please click on the following link.
Click Here
After downloading the driver go to My Computer . Right click on it and go to properties and then device manager and find the sound section and update the driver with the download driver. And problem will be solved.
