I'm trying to find unwanted processes on my PC. Can anyone tell me the usual or common processes on the Task Manager of a PC running Windows Vista Home Basic?
Hi Einar,
Full of those annoying list of processes in the task manager, then worry not because I will show to you the most important processes in your operating system, or in your Windows Vista Home Basic Operating System to be specific. Well, there are a lot of processes that are common to users, but there are only 10-7 processes that are very essential in your Windows Vista Home Basic Operating System. Here is the list.
Common Processes:
acrotray.exe
csrss.exe
csrcs.exe
ctfmon.exe
explorer.exe
iexplore.exe
lsass.exe
rundll32.exe
services.exe
smss.exe
spoolsv.exe
System
System Idele Process
taskmgr.exe
wdfmgr.exe
winlogon.exe
winword.exe
Essential and Important Processes
>>taskmgr.exe
>>explorer.exe
>>svchost.exe
>>spoolsv.exe
>>lsass.exe
>>services.exe
>>winlogon.exe
>>csrss.exe
>>smss.exe
>>System Idle Process
Just end or disable all of those process you simply don’t need, and leave only the ones you need and ofcourse, the important processes.
>>Mathew Joni<<
