Loading error in Microsoft Office Outlook
I recently purchased Silent mail but after I installed it on my pc I got an error message after I started outlook. When I uninstall Silent Mail the error box doesn’t pop up any more. I extremely need you suggestion to fix this issue.
Error Message: Failed to load option. Error code 2
Best Answer by Walton Stockstill
Answered By 0 points N/A #186410
Hi Jason,
                This can be an issue of compatibility between the two email clients. You may want to check if Silent mail works without problem with Outlook. There is a specific version of Silent Mail for Outlook so check the version you got if it is indeed the copy for Outlook. Make sure also that you have installed Silent mail using an administrator account for it to work properly.
Answered By 0 points N/A #186411
So far as I have understood your problem, it is purely to receive a sent mail copy, or simply you want hidden BCC. There are a number of free tools available to do this. Use these free utilities, if software is not compatible with your email client. It's obvious that you can't change your primary email sending client. You can download Hidden BCC from softpedia website. It is very much like your silent book but will work fine, without any issues.
Answered By 590495 points N/A #315864
If you can’t uninstall SilentMail the normal way or from the Control Panel, try removing it using third-party applications like Revo Uninstaller. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select SilentMail among the applications and click “Uninstall”. Follow the normal uninstall process.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then restart the computer. After booting, see if Microsoft Office Outlook runs properly again. If this doesn’t work or Microsoft Office Outlook still has errors, try to uninstall and reinstall it.
You should also check if your version of Microsoft Office Outlook is compatible with SilentMail. SilentMail supports Windows 2000, Windows XP, Windows Vista, Windows 7, and Windows Server 2003. It works with Microsoft Office Outlook 2000 until 2010. It requires Intel Pentium 2 or faster processor, 64 MB RAM, and 10 MB free space. If you installed the trial version, check if the trial period is not yet expired.
The free trial works only for seven days (7). For more info, go to SilentMail for Outlook Product Description or to download it again, go to SilentMail for Outlook.
