LMS 3.2 digital signature error
Hi everyone, I am getting the following error from LMS 3.2 server.
Can someone please explain why this error is happening?
And how can i fix this error?
Thanks in advance.
The application's digital signature has an error. Do you want to run the application?
Publisher: CiscoSystems Inc.
Answered By 5 points N/A #153623
This is nothing to worry about. It is just an innate feature of windows 7 to detect lack of digital signatures on any running software installed on the system. The Publisher of this software is Cisco Systems which is well-known multinational company. You can go ahead and click on the "Run" button and it will take you through.
Also, if you check the "Always trust content from this publisher" box on the left, your PC will remember this setting and will also stop prompting you the same way in case you install another software from cisco Systems that does not have a digital signature for any reason.
