Line 6 Monkey- Transaction failed
Hello People! I have installed Pod Farm Application to my computer, and when the installation was on the Optional Add-Ons Tab, I clicked the active purchase button, and I entered my license and I got this error message, what is wrong?
Is it on my license?
Line 6 Monkey
Transaction failed.
Reason: (Code 80003023) License key has already been activated.
If you have Popup blockers, anti-spyware, or anti-virus programs running, try temporarily disabling them.
OK
Answered By 10 points N/A #118785
The  problem is being caused by the antivirus program or program blocking the program from executing for suspecting the program to be harmful to the system, and therefore you will need to disable the antivirus program and the firewall program temporarily so that you can use that application, and when you have finished using it you will have to enable those applications again so that to protect your PC from any threats.
  • On your computer click on start.
  • And then click on Control Panel from the list of programs.
  • The control panel window will open.
  • From it look for the security center and click on it.
  • And the disable the antivirus and the firewall applications.
  • Save the changes and exit.
You should be able to use the application now.
Regards
Thompson Locker
