Line: 22 Error: System’ is undefined
Hi Friends,
Have a look at the error message below. I am receiving this error message with my vBulletin Message frequently.
I do not understand the runtime error. Have you any idea for the runtime error?
Please help me to get a remedy.
I will thankful for all help and support.
Error
A Runtime Error has occurred.
Do you wish to Debug?
Line: 22
Answered By 0 points N/A #139895
I can help you fix the Run Time Error on your computer. I suggest you to follow these steps:
>>A runtime error is an error which occurs on execution of a program.
>>Make sure you are using the latest version of VBulletin on your computer.
>>The latest version of VBulletin is 5.
>>If updating the program to the latest version does not help, try reinstalling the program onto your computer.
>>Make sure you create a system restore points before performing any troubleshooting.
>>Make sure the computer date and time is set correctly.
This should fix the issue with VBulletin on your computer.
Skarbos Jay.
