“License Application Disaster – Application Disaster please attempt reinstalling”
I received this error message: "License Application Disaster – Application Disaster please attempt reinstalling" but re-installing is not functioning. What should I do?
Best Answer by Sharath Reddy
Answered By 0 points N/A #97712
HI
The problem is showing that your software is not working properly and so you need to re-install your software but the reinstalling is not functioning then you needed to change your version in my opinion and then install that new version so it will work. I think this is the possible solution for this, otherwise the only option is to install the new window again and then install the same version and if it will not work then re install the change in version and then check hope this will work and this will solve out your problem. I think this will guide you to the right end.
Answered By 590495 points N/A #97713
It’s kind of confusing. It would be better if you mentioned the product’s name so we know what application we are dealing with. It seems that the problem here is somewhat related to the license of the software. There are instances that this problem is caused by corruption of files and sometimes can be fixed by reinstalling.
If you already tried it and still don’t work, try this method. If the program is already installed, uninstall it from the Add or Remove Programs. Click Start, Control Panel, Add or Remove Programs. Select your program from the list then click Remove. Restart your computer even if it doesn’t ask you.
After booting open Windows Explorer then navigate to “C:Program Files”. Delete the folder of your program if uninstalling it didn’t remove the folder. After that install the program again then see if it works. If the demo period of the program is already expired, you need to supply it with your license code.
If you don’t have it then you need to purchase it from the program’s website. You will not be able to use the program again unless you purchase a license key for it.
