elin ortie
10 points
Posted on - 02/06/2013
Hello expert, My friend is using the internet via a LAN line.
He asked me to explain about network command tools to solve some problems on his connection.
Please can you lead me to operate net tools CMD to help my friend?
Lead me to operate net tools CMD to help my friend
Hi, Friend, I will suggest follow the following tips.
1. When Network connection failed you will try to check it by typing in the start menu  and type cmd and enter.
Ten type ping followed by your IP address.
2. If you are notified that your server not found. You will need to go Start Menu and then run type ping and space type server IP address and press Enter. If reply come from your network is OK. Otherwise it is a problem with your server.
Thanks
 Hi Elin,
Hope you are doing well. Your friend is using the internet via a LAN. It’s really hard to solve network problems.
You want to use net tools CMD. It’s enough to solve most problems. Please follow this link.
You will get here many useful information. Like 'how to know if your cable is connected, How to know if your gateway is working' and many more .
Hope this will help you. Take care.
Regards
Kknisely Kate
