No of visitors who read this post: 1217
Category: Scanners
Type: Question
No votes yet
Hello Guys! When I used my inventory scanner I got this error.
Where must the loc32vc0.dll located?
And how can I install it to my computer for me to run my scanner?
Please send me a simple step to configure it.
LDISCN32.EXE – Unable To Locate Component
This application has failed to start because loc32vc0.dll was not found.
Re-installing the application may fix this problem.
OK
Comment viewing options
# Comment Id: 42108
Did you uninstall Norton antivirus just before this error showed up?
If the Norton antivirus has been removed, sometimes it also removes a DLL file that is related to for LANDesk.
When this happens, after next PC restart the LDISCN32.EXE application which runs on startup will show error like this one - "This application has failed to start because loc32vc0.dll was not found." To correct this error problem, Install Norton again & run the Norton’s Computer Management Software installer.
Even you run this option before, Do it again.
Running the Norton’s Computer Management Software installer again will fix this problem.
Regards
Crawly Math
