Laptop show error text “InCDgui.dll”
My laptop is displaying Error text "InCDgui.dll". And a blue screen appear.
It is continue from many days but I cannot solve it.
I have tried to find on the Internet but cannot get proper results please help me to recover this problem.
Best Answer by Darren Mac
Answered By 0 points N/A #117125
Hello Zishami,
Icdgui.dll error message is nothing but System malfunction.
It basically arises when one or several files in the Operating system gets corrupted or virus infected.
Therefore,the first thing I would suggest you is to run an antivirus scan and check for virus, if still the problem persists then here's the solution for it.
Just download and save this application to fix this error Install it and then press Scan and then press the REPAIR ERROR button whenever scan is finished.
Once that is done just Reboot your PC and that it you're done.
Good Luck.
Thanks!!
Answered By 0 points N/A #117126
It is a problem that arises once your computer is infected by viruses and to fix it is by either doing a system repair or reformatting.
Solution 1:
Repair your operating system and then once the repair is done. I am sure that plenty of virus is still swarming your whole system and to prevent this. You have to install an anti virus once you repaired it, and then scan your whole computer including the drives that you use and the USBs you always insert.
Solution 2:
Reformat your computer system. Sometimes this is your only option but with a price. You have to delete all of your files so make sure that you create a back up of all the important files in your computer.
