Hi Techyv,
I am using Windows XP and I am in need of LAN Card Driver for Dell Win 32bit. Please do the needful for providing the downloadable link towards the mentioned driver.
Thanks in Advance,
Cruz D Hatchell
points
Hello Cruz,
You were searching for LAN Card Driver for your Dell PC. It is available on their driver support page. Visiting this page, you will be able to find out the perfect driver for your PC.
Here is the link that will directly redirect you to Network driver downloads.
Hi Cruz,
Try to download this driver and install. Its hard finding drivers for windows xp now specially for your dell win 32bit but there are still downloadable drivers but hard to find here is the link for your LAN card driver. Hope this helps you if not try this other one
