Lack of updated graphics drivers
Hi there,
I have this problem from my graphic driver. I have installed the latest version of this driver and still I have this error. Reinstalling of the driver and the game is not working. Does anyone experienced this before ? How can I solve this ?
Thanks !
We’re sorry, but it seems there was an error while trying to render aspects of the game.
To solve this error, it is recommended that you update your graphics drivers.
If you are unsure of how to update your drivers, please click ‘Fix the problem’ for more information.
Fix The Problem Cancel
Answered By 590495 points N/A #182380
Since the problem with your graphics adapter started with your game, try first restarting your computer and try again. You should also check if your computer meets all the requirements for the game. Because Windows 8 is running normally without any issue with your video card, I think it is only your game that will throw this error.
To properly check the issue, check again the game’s system requirements and verify the required video card. Most of the games I’ve seen require a video card with at least 256 MB video RAM or higher, OpenGL 2.0 or higher, and sometimes Pixel Shader are required. If your video card doesn’t have one of the required features, the game will not work even if you update your video card’s driver.
If in case it turns out that you have an unsupported graphics adapter, you can either uninstall the game or purchase a new video card. Most of the modern video cards today already have these features so you don’t need to look for it specifically but you can also do so if you like if you prefer checking the available features.
