Is Kernel Outlook PST Repair compatible with Windows 8?
Hi guys.  i just installed the Kernel Outlook PST Repair version 13.02.01 for viewing and repairing corrupted .PST files without using Microsoft Outlook.  When launching the program, my PC just freezes.  You can't do anything but just do a reboot.  Is this program not compatible with Windows 8?
Answered By 90 points N/A #141634
Hi there
I’m afraid that there is no solution for overcome this problem since windows is a touch based OS and still Kernel Outlook PST Repair version is not able to come up with a compatible version for windows 8. But you can try the latest version of Kernel Outlook PST Repair in order to solve this problem. But if you are using Microsoft outlook 2013 it will give you a great experience than the old outlook versions
Best of luck
Taylor B Campus
Thank you
