No of visitors who read this post: 182
Category: Anti-Virus
Type: Question
Author: Powel Edward
No votes yet
Hello friends,
My Kaspersky is not working. I have tried over and over to get it going. Please help. My system has a virus, I'm sure.
Optional Information:
Computer OS: Windows XP
Browser: AOL
Already Tried:
Everything I could think of.
Thanks to all.
Comment viewing options
Check the validity of the Kaspersky Antivirus software currently running with your system. The license key may be expired. So you need a valid license key to activate the software. You can collect an update copy of Kaspersky Antivirus from the market. You may also update the software from their respective website. You can also get the free Kaspersky Antivirus software from there. It will also be secured for your systems. You can also use any other Antivirus software to protect your system if readily available. So do it now. However, updated Antivirus is very essential for smooth functioning with the PC.
  I hope you understand it.
