Java script de MCafee pluss
I am using McAfee pluses antivirus but my antivirus plus is not working properly.
I tried to install but it shows the message installation can't start.
I think I have trouble in installation of Java script if any one know about the installation of JavaScript de McAfee then please help me as soon as possible.
Answered By 5 points N/A #141548
Dear,
You haven’t specified your pc’s “Operating System”.
Is it “Windows Vista” or “Windows XP”?
If you are a “Vista” user then try this;:
1. Click on the “Start” button under the search type “cmd” without any symbol. You will see an icon right click on it and select “Run as Administrator” then type “regsvr32 jscript.dll” and press “Enter” key.
2. New message will appear for confirming that your process is successful then “Restart” your pc and then “Download” McAfee.
