Java Error: ā€œCould not create the Java virtual machineā€
Anybody who is familiar with JAVA please try to help me.
Java download error:
"Could not create the Java virtual machine."
When I was about to end the download process I get 3 error messages that read the same,
"Could not create the Java virtual machineā€
I first had this error message about an hour after starting a Minecraft server. It was suggested to me to reinstall all Java files. Now the message appears upon downloading the program. What am I going to do?
Please post your answers. Thank you!Ā
Best Answer by Harpe byers
Answered By 5 points N/A #92183
Hi , Rochelle hope the following steps will guide you in fixing of this issue.:
Ā
Ā
ā€“>Firstly the reason may be the installation of java may not be done correctly so its better to check and run the application with clear installation.
Ā
ā€“>If you have installed correctly then the next step if you get the error is to update to be done by using " https://www.oracle.com/technetwork/java/index.html ".Ā
Ā
ā€“>Even if the 2 steps also Ā fails to fix your issue then open the DOS prompt by moving to the folder with VUE and then running theĀ
Ā
command: " Ā java -jar VUE.jar Ā ". Ā Ā
Ā
Thank you..:-)
Answered By 10 points N/A #92185
Hello Rochelle,
Unfortunately you encountered all the three JAVA common installation errors at the same time.
First understand that a correct code of JAVA shall be like ~java java ā€“Xmx1500M
Please try to note the mistakes and follow these steps to remove it:
1. There shall not be any space between ā€“Xmx and 1500M,
2. It shall be 1500M and not 1500MB or if its 1500KB then it shall be 1500K i.e. only the first letter of KB or MB,
3. There shall not be any space in between 1500 and M or K.
I am sure you will find it and remove it.
