Is it possible for Linux remove adobe DRM
Hi TechyV users!
I have DRM that I want to remove. But it seems that I don’t know how to do it.
Here is my question, Is it possible for Linux remove adobe DRM?
Are there ways or methods to remove it?
Are there software to install to remove DRM?
My friend says that there is also a plug – in that I need to download and install but he doesn’t say what it is. What is this plug – in?
Any comments would be a big help.
Phillip Arthurr
Best Answer by Holt Huse
Answered By 0 points N/A #170768
Philip,
For those who are not familiar with DRM (Digital right Management) it is intended to prevent unauthorized use. You can't Freely share the file you bought. Most DRM removal tools should be compatible with Linux.
Your friend can be talking about the DeDRM plugin for calibre. It is an open source, eBook management and a conversion utility it is maintained by Kovid Goyal. In order for you to use the DeDRM plugin for calibre, it's necessary to install calibre first. You can download the latest Version from https://calibre-ebook.com/download.
Now, on how to remove Adobe DRM you can use an Adobe EPUB Removal, it can help you read your adobe PDF eBook on many devices or computers as well, it's an easy-to-use interface it can easily remove adobe DRM.
It creates a new eBook file that you can view with many devices w/o limitations. In order to remove DRM you have to check if the file has or doesn't have DRM.
If your file is protected by DRM you will not be able to read it when using Adobe Reader you will see a prompt telling that the document requires DRM features supported by Adobe Digital Editions.
And will ask you if you like to open it in The Digital Editions. You cannot read and convert books with DRM, in order to convert files PDF, WORD, MOBI etc.
You need to remove the DRM first. Before removing DRM, make sure that you can use books normally. In removing DRM you can use Adobe Digital Edition in downloading the book.
To remove DRM from Adobe start the DRM conversion process, download DRM removal for Linux. Open the file you which you need to convert you can open more than one file one time.
If you can't manually find the files you can click on "Find Files" Button the computer will automatically find the files in your computer. Once you have your files already open just click on "Start" button all the DRM will be removed in a few Minutes. Once DRM is removed books will be put into the "Output Folder" then you just need to click on "view" to view the new books.
Answered By 0 points N/A #170770
Hello, Phillip Arthurr!
Yes, it is possible to remove Adobe Digital Edition DRM. To remove it, you need to use a third-party software. The name of this software is 'Adobe DRM Remove'. This is very easy to use.
First, install the software. Then run the software. Once it is already running, select the file or files where DRM should be removed. Here is the download link and other useful information. Hope you will be able to do this. If you have other issues, just visit this site.
Have a good day.
Answered By 0 points N/A #170772
Hi Phillip,
Yes, it's possible to remove the ADOBE DRM for Linux. Make sure you have Python installed. If not, download it using your standard methods for finding applications. Make sure you install Python 2.6, not the new 3.0.
Once you have Python already, mobidedrm.py will remove the DRM from MOBI eBooks, for example, and you can buy MOBIs using any web browser. This is a command-line program, which means that it is no harder to use for Linux than from Windows.
Answered By 0 points N/A #170773
Using Windows 7, follow the following Instructions carefully (It may differ in Mac or other Versions of Windows).
Answered By 0 points N/A #170774
Hi Philipp,
It is possible to remove Adobe DRM in Linux by using a software called Calibre, a software used for eBook management.
The plugin that your friend mentioned was called DeDRM plugin for Calibre.
This plugin is needed to remove DRM.
You have to install Calibre before installing the DeDRM plugin.
For specific instructions, you can see it here.
Answered By 0 points N/A #170775
Phillip,
Yes it is possible to remove adobe DRM for Linux. There are three methods that you can use to do this.They are as follows:
* Using ePUBee.
* Using free python scripts.
* Using Calibre Plugins.
What you need to do is First of all Install Adobe Digital Editions (ADE) v1.7.1, and Authorize your copy of ADE, then download the epub files to desk then make sure the epub files can opened on Adobe digital editions.
Answered By 0 points N/A #170776
Hi Philip Arthur,
Yes, it is possible to remove Adobe DRM (Digital Right Management) in Linux by using ePUBee, free python scripts and Calibre Plugins.
What you need to do is First of all Install Adobe Digital Editions v1.7.1, and Authorize your copy of ADE, then download the Epub files to disk then make sure the Epub files can opened on Adobe digital editions.
