In isa 2006 how to block camfrog?
Hello experts,
In isa 2006 how to block camfrog? Is there a way to block the annoying pop up icons and software in the desktop to be blocked and be sure that will never come back again, can you give me some information or solution to get this things done?
I need your guidance. Thank you.
Best Answer by Maud Matland
Answered By 0 points N/A #184343
If should use filter for HTTP in support of blocking any distinct traffic. There is a software ‘Network Monitor’ which can mark out the packets of camfrog as well as general signatures. These can be applied as blocker to that exact traffic. Download and install these software.  These should be configured accordingly.
Answered By 0 points N/A #184344
To resolve your problem I would recommend you to download “Pop up block Camfrog Video Chat”. Just open the given link to solve your annoying problem.
http://www.downloadatlas.com/video_popup_block/camfrog-video-chat-by-camshare-lc.html
You can track announce, and block incoming calls using “BLOCK CAMFROG”. You will be able to control all program using Block authorized utilities.
http://www.supershareware.com/block-camfrog-free/
I hope you may fix your problem.
