I'm having problems with iPhoto. When I tried to launch the application, the banner menu appears but it does not open to a screen where it should display images. Double clicking iPhoto icon does not bring up the pictures either. How can I restore iPhoto back to normal?
Hi, hope that you may be solve your problem with my solution. It’s nothing exceptional that occurring problem with app stores application. And problems can be happened witha anything. So don’t be take tension. Just follow the instruction here I given below-
1. Here first suggetion is backup and try to rebuild your iphoto library. While you will launching iphoto, hold down the command and option, You also hold down Alt. To rebuild iphoto library, use the resulting dialogue. At last you now choose Rebuild iPhoto Library Database for automatic backup.
2. In this second option you can Download iphoto library manager from here- http://www.fatcatsoftware.com/iplm/ and use it to rebuild the function. May be the problem of launching problem of iphoto will solved.
If you faces any other problems with iphotos you can also visit this site- http://www.steves-digicams.com/knowledge-center/how-tos/photo-software/common-iphoto-problems-and-how-to-solve-them.html
