Hi friends,
I cannot see anything on the iPhone application, on a dual screen mode of the computer. Well, this is the first time that I' tried if this would work on a dual screen. I'm not really sure, if this is going to work. It's working, if the dual mode is off.
Yes, I just want to maximize my 2 monitors. I also need a space on the screen, to see the job I am working on while opening applications on iPhone.
Anyone knows about this? Please let me know. Any suggestions or tips would be greatly appreciated.
Hello Amy,
I have learned that iPhone applications can only handle up to 2048x2048 resolution. If you are running an application beyond that maximum resolution, you will only get a black screen That's frustrating right?
Stay tuned to the iPhone applications news and trends if they will upgrade their maximum resolution. For the meantime, run an application which has a bit lower resolution. Meaning, if you are running an application with more than 2048x2048 resolution, choose anything lower than that.
If that doesn't work, I think that's a problem with iPhone applications already. Maybe you can control the system with only one screen. They should be able to release an update.
Best Regards,
Karen
