Iphone 5c. Iphone 5s, or Iphone 6. Which is better?
Hello! I have been using Samsung S4 for quite a long time now and I am thinking of changing my smartphone now I am thinking of using an apple IPhone for now. Out of the three apple devices mentioned above which one is better in all aspects? I mean should I take the risk of buying IPhone 6? Because very soon the next version of IPhone will be out there in the market and this will largely affect the worth of IPhone 6 in comparison with 5c or 5s.
Answered By 0 points N/A #180615
Hello Joseph,
I have been an Apple user for 4 years now. I recommend that you get the iPhone 6, instead of the older versions. The depreciation are of the 3 phones you've mentioned are somehow close. Either way, you'll lose same amount/percentage of money. Also, most likely, when the new iPhone is released, it's patterned in iPhone 6. Similar to how iPhone 3gs, 4s, and 5s where patterned to their predecesors.
Answered By 572870 points N/A #180616
I also think iPhone 6 is the best of the 3. They almost have the same features like the operating system, all 3 can be upgraded to iOS 8.3, all 3 supports LTE, Bluetooth are almost the same as well as with the camera, but iPhone 6 has the highest internal storage capacity. Here’s a short description.
The Apple iPhone 6 is a 4G/LTE Smartphone. It supports 2G, 3G, and 4G networks and uses a nano-SIM card. It was unveiled and released on September 2014. It measures 138.1 x 67 x 6.9 millimeters and weighs 129 grams. It has an LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 750 x 1334 pixels screen resolution.
It is protected by Ion-strengthened glass with oleophobic coating plus multi-touch and Display Zoom support. It runs on iOS 8 upgradable to iOS 8.3 powered by Apple A8 chipset, Dual Core 1.4 GHz Cyclone [ARM v8-based] processor, and PowerVR GX6450 [quad-core graphics] GPU. It doesn’t support microSD. It runs on 1 GB RAM with internal storage available in 16 GB, 64 GB, and 128 GB capacities.
The primary camera supports 8 megapixels at 3264 x 2448 pixels with dual LED flash [dual tone] and phase detection autofocus. It features geo-tagging, 1/3'' sensor size, face and smile detection, 1.5µm pixel size, simultaneous HD video and image recording, HDR [photo/panorama], and touch focus. It can record video in 1080p at 60 fps and 720p at 240 fps.
The secondary camera supports 1.2 megapixels and can record video in 720p at 30 fps with HDR, face detection, and FaceTime over Wi-Fi or Cellular. It supports Bluetooth 4.0 with A2DP and LE, GPS with A-GPS and GLONASS, NFC [Apple Pay only], USB 2.0 with reversible connector, and Wi-Fi 802.11 a/b/g/n/ac with dual-band and hotspot. It includes accelerometer, gyro, barometer, proximity, and compass sensors.
The built-in Safari browser supports HTML5. Java is not supported. It runs on non-removable [6.9 Wh] Li-Po 1810 mAh battery with standby time up to 250 hours on 3G and talk time up to 14 hours on 3G.
